Xron-ified Android (alpha 3) - INSTALL THIS!!!!!
Xronified has sorted every problem for me, well B1.2 did, the newer one caused problems with 2D games. Anyway did you make sure you turned off anything to do with mobile data ? That is one of the oldest solutions for CM7 on T-Pad and I don't see it mentioned that much anymore.
Turn off mobile data? Where? Since tp is wifi only I don't see any settings. Loading 2.9.1 over 2.8 seemed to solve wifi so far. I also changed wifi system name to less than 16 characters.
Sent from my EVO4G using Tapatalk.
I reflashed after checking everything on my comp I made sure the MD5 matched and everything and all works fine now.
I'm using CM9 now so not sure exactly where the setting is on Xron, Somewhere in settings, probably under wireless and networks. It was their because cm7 (android 2.3) is a rom that was developed for phones and not tablets. And because the T-Pad doesn't use a sim card, leaving the mobile data turned on caused problems.
It is possible that the Xron guys managed to remove it from the rom altogether to simplify the user experience.
this rom freaks out if I remove the dialer nothing is stable and it reboots everytime I turn the screen off.
Ashok Dharshan
