Zagg glass screen S7 edge
thunderbomb
72
I've come to the final conclusion that the Zagg tempered glass screen protector for the Galaxy S7 edge is a piece of garbage. 3 hours on and it popped off without even putting a case on it. The adhesive is only under the black areas. Don't waste your money. Junk.
I've come to the final conclusion that the Zagg tempered glass screen protector for the Galaxy S7 edge is a piece of garbage. 3 hours on and it popped off without even putting a case on it. The adhesive is only under the black areas. Don't waste your money. Junk. //uploads.tapatalk-cdn.com/20160916/868e055c78ef2f052a3c0d838fa1e75c.jpg
I just installed an Armor Shield non tempered glass and I have to say I like it a lot. It seems to be hit or miss to find a good TG that works.
I Used the wet install from Skinomi. Perfect!! In my Otterbox Symmetry case and no issues at all so far
So day 3 update. One side peeled up a bit. I sprayed a little solution under the lifted area and let sit over night. So far so good. If it lifts again I have a solution in mind. Use a ruler and sharp blade and shave off a little bit on each side before applying it to the screen. That should work. The top and bottom are not peeling.
I've been using it with unicorn beetle pro for a few months now. Works fine. My case holds the screen in place so there is no way it can pop off.
I would like to use a thinner case but worried about it popping off. Zagg's website states they are making a "case friendly" glass protector "coming soon"
The case looks nice but what's the point of its not holding up properly. To get a screen protector for S7 Edge which fits perfectly would be great but that's not the case. The Unicorn beetle case looks really nice and will protect the phone from drops but I doubt there will be a screen protector that goes well with it.
The Beetle case looks really nice mate. But are you rocking a screen guard on top of it. If so which one?
I've been using this case with my Note 7, and the wet Zagg HD screen protector. It tends to squeeze the screen protector in the top and bottom areas, with the occasional lift along the edge panels. I'm guessing that shouldn't be an issue with the TG screen protector. But I'm wondering if there is any rainbow or halo effect on the screen with the glass screen protectors? How about the clicking noise when typing or tapping on the screen?
Also, does anyone know if Samsung ever put out an "Official Samsung Screen Protector" like they did with the Note7? It wasn't tempered glass, but it was just as smooth as the naked screen. It would have went very well with my Beetle Pro case before I returned it because of the recall.
I notice a little rainbow effect when screen is off and hold it at an angle. With the screen on there is no effect. No clicking noise either, I think the case holds it down pretty well so it doesn't lift.
I'm still waiting for zagg to have their new version out, I honestly dont think they will come out with new product though.
I had the Bodyguardz hd contour installed and it hasn't peeled up yet. It doesn't go all the way to the edges and it's been about a month so far.
I have the Zagg glass screen on my S7 edge and love it. It has not peeled or hinted of lifting. I use a case by Incipio and the two meet exactly at all the edges so there is no overlap and no gap.
The zagg glass is too big and not case-friendly. Therefore, kinda useless.
This works well for me:
...arrived this morning...and I LOVE IT!
I had the Zagg glass and it did not stick well which made typing more difficult.
I now use the one done by best buy geek squad. They cut it and put it on. It has free replacement and works great. I'm in Canada if that makes a difference with the best buys.
Andacar
