ZAGG invisibleSHIELD Discussion
Had a Zagg on my Storm1 for 14 months now....same one, no replacements. May be lucky but have had 0 problems with it (other than the constant fingerprints to clean - but thats going to be with anything).....Ordered a Zagg full body (easy install) for my new DX. To bad I will get the Zagg before I even get the phone.
As others have said it definately takes a few days to smooth out, never feels as smooth as the bare screen....but its smooth enough to deal with when you think of the protection it provides.
Was tempted to buy the full/complete coverage but no way I wanted to deal with all the tiny pieces.
I just got my second zagg front protector in. First one I took off to try to straighten it and never could get it back right due to dust, hair, blah blah. Using the Steinheil ultra clear right now; it has a good feel and looks pretty good, but I almost like the zagg better.
I'm liking the Zagg quite a bit. One note for it. Be sure to wet your fingers with the solution BEFORE you peel of the backing! Otherwise you will probably be fighting it sticking to your fingers and/or fingerprints on the screen... :/
Scott
From my Droid X using the SlideIT keyboard and Tapatalk Pro
I had the Invisible Shield first. I loved it at first, pretty invisible to the naked eye. Definitely a grippy surface which wore on me. Good with fingerprints but began to show some more permanent smudges.
I just put on a Steinheil anti fingerprint. It has a sheen that makes very visible to the eye, has a reflection at angles. Smoother surface than the Zagg for dragging. Easy to read through. I have spares of both so I will keep using all at various times, plus try the Steinheil Ultra.
alejandro109322
