Zeus + Infuse = Heaven!!
Flashed Zeus v. 6 last night. Also flashed Entropy's DD. Mongo's toggles on top of that. Love it so far. I decided to move on from Zeus 5.2 because I was experiencing some unexplainable boot loops. So running v. 6, and so far so good. 5 hours 14 mins still at 75 battery capacity.
Battery life is great on v6 but I'm having a lot of issues. So far I've had my phone reboot 10 times in the past three days over little things.
Pressing and holding on an app to remove it from a home screen makes it reboot if the phone has been running for aver an hour.
Using a live background makes the phone reboot within 3 hours and the background is no longer there (being replaced by the wallpaper I used before)
and the ics clock widget that comes with the theme gets stuck once or twice a day requiring a reboot to fix.
General issues:
The background no longer scrolls with the home screens like it did in v5.2.
I cannot go into landscape mode without the wallpaper being put into a weird aspect ratio, I think 4:3 instead of 16:9 like it should. (just thinking of normal non-widescreen and wide screen, I'm not sure if the aspect ratios are the same for phones)
the battery life however is simply amazing. 15 hours of use yesterday (light use) and it was at 56% battery life. I'm going to flash the rom again and see if that fixes these problems because no one else seems to be having them.
General issues:
I can tell you that I have not experienced the background scroll or wallpaper issues using Go Launcher Ex. No reboots thus far.
hi i am new to the whole hack and swap set up , i just got an infuse 4g , the first thing out the box was to root and unlock now im stuck , can someone help giude me through the mod process so i dont mess the rom over completely
Zeus6 is better than Zeus 5.2 in my opinion, though there is a known issue of SOD on Zeus6. I have experienced only 1 SOD for about a week, so it's not a major issue at least for me. dman knows the problem (I think it is because of EDT tweaks?) and I assume he's going to fix it later on.
But besides that I don't have major issues with it. I did delete TW4laucher before flashing rom because TW3 is more stable on infuse in my opinion (I'm using ADW EX launcher anyway) Battery life is really monster.
It's funny since I complained alot to ATT+samsung about sluggish official gb update but now I'm addicted to flashing roms :p. I tried 3 roms (R3VELATiON, MIUI and Zeus) and think I'm gonna stick with Zeus until my contract is up.
how to root
how to install clockworkmod
how to install Zeus
That's what I did. He's pretty good about explaining everything. Be sure to do all the backups and restore points...also GTG ultimate unbrick is a must have just in case you brick your phone.
I had zeus 6 and it completely froze up and I couldn't even reboot back into it. I said screw it and went to the R3velation rom and like it so far. But every rom I've tried so far has one issue or another. If this continues, I'm just going to go back to stock. I need my phone to just work and am tired of playing games.
And yes, I did everything by the book. (did all wipes and formatted)
The roms are excellent when they work, but it seems like after a few days something always goes wrong. I appreciate all the hard work that goes into them, but perhaps the devs aren't as good as they think. I may try the aeon rom if r3velation doesn't work out, but after that it's back to stock. Enough is enough.
Be prepared Zeus ZTR, will be coming in a couple of days...that's what I'll be flashing next. ;)
Sent from my Galaxy Note
Rom: The Collective The-Unofficialv1.0 Alpha-9
It's here and it's 100 times better than build 6. I wouldn't have thought that could be possible until now.
Sent from my SAMSUNG-SGH-I997 using Tapatalk
couldnt get no farther than the link you supplied said error 404 like its a dead link been running into that alot here lately as far as looking for rom's for the infuse
csbnionlien
