Yes, install Xionia CWMA custom recovery. It will install custom ROMs and it won't brick if you do resets from within android.Ok after many different tries, reinstalling z4root I got it to work, but mostly rooting combinations including superoneclick and many restarts.
Now if I load Xionia CWMA
Can that also load custom roms
Not sure where to go from here
As long as you have CWMA recovery prior to upgrading and use LG Mobile Update you should be fine. Just rerun the FlashRootVD-signed.zip after the upgrade.If I upgrade to VD won't I lose root if I decide not to go with a custom rom?
http://forum.androidcentral.com/lg-...covery-xionia-clockwork-cwma-v1-2518-6-a.html
After that, use LG Mobile Update Tool to upgrade to VD.
Then choose which ROM you want, put the zip file on your SD card, boot to recovery, wipe data/cache/dalvik (sometimes needed), and select the zip file to flash.
yes i used the KP500 and LG mobile updater to force flash V9. then i rooted with Z4root. I do have quick settings and use the hotspot.
so, i go to that site, Custom Recovery Xionia, and the part i am stuck at is here:
"via adb shell or terminal type this from root # shell" ... i guess that is the part i dont know how to install this or if i should.
I would like to keep the hotspot working, have root and have the latest update to my phone with ZVC or ZVD. can i have all those or is that impossible?
thanks
linkin8r
