ZVH OTA update.zip
I need to revert back to the ZVD update. I am currently using ZVH (GB). Do you have the update.zip file for Froyo? And.. if I flash it from stock recov. Will it brick my Optimus?
There is no update.zip to go from ZVH/GB to ZVD/Froyo.
You need to revert using LG mobile update tool via KP500 or KDZ.
KP500 instructions are in my signature.
I have an SW ls670zvh with a baseband of ls670MVH_6150. The recovery is stock. do I need to revert?
Also, as I followed your thread I noted TWO (2) UPDATE FILES. The second file is modified... can I use the modified file?
What are you trying to accomplish?
Which recovery do you have, stock V9 or stock VD?
Which files are you talking about and what do you mean by "The second file is modified"?
vd recovery --- is this made by clockwork?
I used gingerbreak to root, but no other changes. I want to, but I've officially diagnosed myself with terminal stupidity shortly after reading this thread.
I used the update.zip and booted into gb, but I dont have service on the phone and did a factory reset, still no service, can someone help?
wipe cache and then in settings (inside android) --->update profile, it may take a few min (took mine a while to get service)
as long as your not rooted right now, and running stock everything, i would call sprint or visit a local store
Tried that, still no service
If you are on stock recovery or xionia you can do a ##786# reset from the dialer.
It is important your phone is on stock recovery or xionia or your phone can brick.
##786# will ask you for your MSL and it will factory reset your data to defaults.
To get your MSL, call Sprint, get transferred to *tech support* and tell them your phone is having trouble connecting and they suggested you do a ##786# reset, but it is asking you for a code, and you are stuck. They will give you a 6 digit number. This is your MSL.
Reactions: Evil_Lite
This worked for me, fixing the PRL/Profile update error XPT Socket... However it doesn't seemed to have fixed the network unknown issue. Anyone figure this part out?
I reverted to Stock Rom and no root. Called Sprint to have a "Hard Reset" done. Took about an hour because they figured I didn't know what I was talking about and went through their normal problem script.
What is the "network unknown" issue? It is not known to me.
BNIDirect terkunci
