S shaneneff Well-known member Mar 11, 2011 94 2 0 Visit site Sep 8, 2011 #1 Does anyone have an extended battery? Where did you get it, and what kind of performance are you getting? Sent from my SCH-I510 using Tapatalk
A anon(94115) Banned Nov 29, 2010 5,697 511 0 Visit site Sep 8, 2011 #2 I cannot answer any of your questions except to say that only buy the OEM one, generics do not work from my understanding and if you have a case and like it, you cannot find a case for the extended battery. You can get pouches, but not a hard case
TMH478 Active member Nov 11, 2009 42 0 0 Visit site Sep 10, 2011 #3 I bought the desktop charger and got a free standard battery. I don't mind swapping them out. Sent from my SCH-I510 using Tapatalk
A anon(94115) Banned Nov 29, 2010 5,697 511 0 Visit site Sep 10, 2011 #4 that is what I am going to end up doing if I find that the one battery isnt enough. I carried 2 spares with me for the Fassy, so I am used to it
C Chris2183 Well-known member Apr 27, 2010 109 7 0 Visit site Sep 11, 2011 #5 I got mine from a VZW store. You will have to buy the battery door seperate as it uses the same battery as the Continuum
S shaneneff Well-known member Mar 11, 2011 94 2 0 Visit site Sep 11, 2011 #6 I ended up getting the docking station with spare battery and charger. Sent from my SCH-I510 using Tapatalk
