MrNoSox, your method worked perfectly. I've wiped my Charge (replaced it with a Rezound) and want to use it at work as an app test device--but not have a VZW contract (or calling ability at all). This gets the job done.
Thanks!
papa54, try doing a factory reset, or data wipe from your recovery boot screen and see how it goes. You'll need MrNoSox's method to get started, IF you don't want to authorize (which is what this whole thread was about). Got a valid SIM card, and have validated already? No problem, you won't ever see that screen again--unless you wipe data and start over.
BTW, I dumped my Charge because it was so buggy. It would lock up about every other day; a kernel process called k3g_wq (pid 54) would start at 3AM most days, and chew up 20-30% of the CPU constantly, until you killed it (which I found out I was able to do using an app called Elixir, and starting and stopping the gyroscope one or two times). We want to use it as a testing device here because our app has problems with it that no other Android device we test with has. Oh, and the android dev from Pintley (a beer rating/logging app) added me to their beta tester list, because the Charge won't even let me log in--something he hasn't heard from anyone before.
Oh, and this is the third one I've had. The first two would overhead and shut down, so VZW gave me new ones. This one is relatively stable. Mine is rooted too, btw.
Glad yours is working for you, may it always be so.
