tdenton1138
Did you tell the phone to install the update? Perhaps you only got the notification. If your phone says ED1 you should still be able to root.
If you do a factory reset will that take you back to ED1?
I'm interested in rooting my Charge. This'll be the first time I've attempted this.
My question is though when I'm looking through my phone's info I see to different things.
My baseband version is still ED1
However my Build Number is ED2
Which on of these am I looking at?
Thank You^^;
I'll give it a shot.
Assuming I don't brick the device I should always be able to restore it to "Factory Default" and try again.
if you are in a custom rom never do a factory restore,,,there is a seperate flash to recover to stock.
but if you follow directions you will be fine
Would be great to know if EE4 can be rooted, now...?
you can do the updateI keep getting a message to update but am afraid to since yall origionally said don't so is it really ok to now?
this helped me with my choice to root thank you.I just flashed Altered Beast v5 after updating to the EE4 update and its working flawlessly. Im really glad didnt want to mess with flashing back to earlier updates and all that jazz. So go get your Charge and root away!!!!
Yes I too am considering getting a Charge and would like to know if it's OK to allow the OTA updates now?
IOW, the root wizards have figured out a way to get around the ED2 problem.
(Edit: I just saw in another ED2 thread that it says not to worry... rooting ED2 is no longer a problem. Phew)
Note: I may never root this phone... I'm not super eager too, it just depends if anything isn't working well enough for me, in which case I *might* consider rooting.
