Help with launcherpro favs and bookmarks
owensch1
364
How do i add new favorites or bookmarks to the launcherpro widget???? Do i have to go back to sense to do that? And how do i switch back and forth?
metalrocker
21
It should pull from the browser. To switch go to Manage Applications, click on whatever Home launcher you are CURRENTLY using, and check "clear defaults". when you press the home key it will ask which to use.
FramCire
183
To add new favorites, you go to the people/contacts and then go to the groups. Click add contact to add contacts.
To add/manage bookmarks, go into your browser and edit them. It pulls the into from there.
Then go to the widget and click the sycn logo on the bottom and it should sync up fine.
FramCire
183
Also, you can make the people widget pick from any pre-made group in your people/contacts. You edit the actual members of the group in your phone book and then hit the sync on the widget.
ecstasy89
