I had been running Community ROM 1.3 for a while now and decided since CM7.1 released a stable build I would try that, but since I had been running a Voodoo based ROM I backed up everything and then did restored the phone to Stock using the method I found here:
***READ THIS!!!!!!*** Going from CM7/MIUI/OMFGB to another rom/Unbricking your device - xda-developers
That did return me to stock DL09 and then did the OTA update to ED05 with no problems. Then I went to install CM7.1 using the method listed here:
Samsung Fascinate: Full Update Guide - CyanogenMod Wiki
But I wasn't able to see my phone when I plugged it into the computer. I then tried to use ODIN and it didn't see the phone either. I uninstalled the USB Drivers and Rebooted and Installed the USB Drivers again and 9/10 the phone isn't even detected by the computer (though the phone will charge), and 1/10 times the phone will be detected by the computer, but it says it's an unknown device (and when it's like that ODIN still won't see it but zadig.exe will see the "unknown" device but I can't do anything with it).
Please help. Thanks
Please help. Thanks
