[Guide] Tools and Information for Mac OS X Users - Updated 04/07
So I'm at the point where I'm trying to root and when the terminal screen pops up it says device not found, also when I first plug the phone into the computer it says device not recognized. What should I do here?
I should also note I stupidly skipped over the root section when I first tried (rushing through this; not good) and ran the cwr terminal before I did the root. After that I lost vibrate and my phone cannot be recognized.
are you able to boot into Clockwork?
No but strangely when i held down the volume buttons while powering up, my computer recognized the phone when I turned it on. I tried to root again and it recognized it until it tried to install superuser and then it said device not found again.
did you make sure that the screen was unlocked and not asleep when it got to that part?
Yes debugging and stay awake is on. Think it's possible I'm already rooted? I've done it before but I was pretty sure it was killed when I updated. Should I try the CWR terminal again?
download a free terminal emulator from the market
open it and type su,,, tell me if you see $ or #
you are not rooted,,,, pull the battery and try again
-click-root/Files/root.sh
Starting installation...
Copying files...
620 KB/s (26277 bytes in 0.041s)
3872 KB/s (1867568 bytes in 0.471s)
18 KB/s (5392 bytes in 0.284s)
0 KB/s (24 bytes in 0.052s)
[*] CVE-2010-EASY Android local root exploit (C) 2010 by 743C
[*] checking NPROC limit ...
[+] RLIMIT_NPROC={3712, 3712}
[*] Searching for adb ...
[+] Found adb as PID 2200
[*] Spawning children. Dont type anything and wait for reset!
[*] If you like what we are doing you can send us PayPal money to
[*] 7-4-3-C@web.de so we can compensate time, effort and HW costs.
[*] If you are a company and feel like you profit from our work,
[*] we also accept donations > 1000 USD!
[*] adb connection will be reset. restart adb server on desktop and re-login.
Mounting system
error: device not found
Moving su
Moving busybox
Changing permissions on su
Changing permissions on busybox
Installing superuser.apk
Rebooting device...
You can now close terminal.
And my phone is frozen unless I do a batt pull. :-\
Copying files...
Mounting system
Moving su
Moving busybox
Rebooting device...
let me try to get intouch with braydon see if he can add a pause to give you and the phone time to create a connection before it continues
meanwhile:when the phone turns back on did you unlock it?
Reactions: FrankWhite77
Copying files...
Mounting system
Moving su
Moving busybox
Rebooting device...
Run the 1-click-remove root. Then try rooting again. You will probably get some errors during the 1-click-removeroot, but as long as they aren't device not found it will have worked
/1-click-remove-root/Files/unroot.sh
Starting uninstallation...
Mounting system
Removing su
Removing busybox
Removing superuser.apk
Cleaning up
Rebooting device...
Phone frozen again.
During the testing procedure, I noticed if the root exploit doesnt finish successfully, my phone would freeze on the second attempt if i didnt reboot in between. thats why your phone is freezing, no need to fret, its not harming anything permanently
yeah I'm not too worried I've seen you guys get people out of much bigger jams haha do you have an instant messenger at all? I feel bad filling the thread with my one problem.
Dont feel bad , this could happen to others its good for it to be seen , maybe they can learn
Braydon is the man! A thousand thanks to him.
So what happened is his phone was already rooted. When the root exploit was run, it froze the phone.
If anyone else is having this issue, please be patient. I am working on a fix. For now, just wait an hour or so and try again. That should disable the root exploit.
