Re: [GUIDE] Galaxy Nexus MOD for Palm Touchstone without solderin
Interesting setup! I'm adding this to post #3. Please update your post with pictures if you can.Just wanted to chime in with another success story
My configuration is:
-charging coil outside the phone, on the inside of a diztronic case.
-Copper tape traces to the edge of the case
-I extended the pogo contacts with copper tape, scratched a small hole in the tape through to the pogo contact, and put a small bit of solder on the copper tape. This makes the tape function as a solder pad, and there should be minimal solder on the pin itself. Should be very easy to reverse if needed.
Connection is pretty bombproof so far, and I love the convenience of this mod. Mine does charge pretty slowly this way, but with Pandora streaming bluetooth audio, and GPS navigation running, I get a percent charge every 4 or 5 minutes. Good enough for car trips.
NFC still works perfectly with the coil mounted as high as possible in the case.
The compass is severely impacted, but I can take the case off whenever I need an accurate compass.
Thanks for the instructions and all the feedback on this thread. If anyone is nervous about this, remember, it is an open source phone, hack it
