Let's talk Kernel,ROMs, etc.
svfd757
667
54
Aokp build 38 with franco Kernel build 181. Probably the best combination I've tried. Very very smooth and extremely fast
Sent from my Galaxy Nexus by way of Tapatalk
Reactions: Xanth269 and bjs188
mpparr
9
Not to jump in and hijack the thread, but I think it applies: I'm looking for a relatively pure ICS experience, but with all most of the kinks worked out. Does AOKP fit the bill in this case as well? I'm planning on rolling up my sleeves and rooting this weekend (I've only had the phone for 5 days.)
SuperChargedJ
332
38
I would also recommend AOKP as well as the rom I'm currently running CMPLX B1ACK ADV6. Recommend kernels would be Franco and Trinity. Trinity is not as well known but it is fantastic! Those who have used it are raving about it.
Jeff43
269
39
While I was a fan of AOKP for some time, I've been running LiquidSmooth since v1.3 and I have never looked back.
Liquidsmooth has a more "vanilla" ICS feel to it, very clean. It's also, in conjunction with Franco's kernel, the snappiest, smoothest, and most fluid ROM I've used.
I'm presently running Liquid v1.4 with franco nightly r185 512GPU. And this combo is awesome! For those of you like benchmarks, I ran Quadrand Standard and got a 3950, not bad, if I say so myself.
The best advise I can give is try them all. It's easy to flash ROMs and kernels. So experiment, and find the one that you like best.
Everyone has different priorities when it comes to ROMs, some are looking for better battery life, some want more customization features, some (like me) just want more speed.
This is one of the best things about having a Android phone. When the phone begins to feel a little stale, just flash a new ROM/kernel and BAM you have something "new" to play with.
daver317
13
Everyone needs to try SlimICS!(slimroms.com)
Super smoothy and creamy :D The fastest Rom I've tried so far (about 5-6) and I seem to be getting much better battery life. I keep wanting to move on and sample the others, but I don't see how it can get better than this.
Reactions: Mild7intl
milesclarence
3
I would echo the people saying AOKP. I've been running it for a few months and it's brilliant.
Lots of customizations and i think it's decently smooth. Not to mention the fact that it gets so much attention and is always improving.
I don't know much about kernels though. I dont' want to hijack this, but if anyone could briefly (in a line or two) explain the big changes that different kernels provide it'd be great.
dancing-bass
1,022
17
exactly what I'm running. Love it. Kinda-sorta tempted to flash back to stock for a few days to see what its like to run stock. I'm starting to forget :p
(although I should add, I have a GSM Gnex, not from Verizon. Still, AOKP+Franco=WIN)
Jeff43
269
39
Kernels can allow you to over/under clock the CPU/GPU, they also have different governors to alow for better battery life or more speed, you can turn off 1 of the cores of the CPU when unneeded, there are also color tweaks that can help in color accuracy.
ruh-roh-raggy
59
12
For general info. about kernels, you'll find great stuff here: http://forums.androidcentral.com/verizon-galaxy-nexus-rooting-roms-hacks/167604-guide-dont-panic-hitchhikers-guide-galaxy-nexus.html
Specific kernel-to-kernel comparisons, sorry I can't help you there. I've been using Franco's for awhile.
Reactions: dmmarck
milesclarence
3
Thanks!
dmmarck
Retired Moderator
Dec 28, 2011
8,349
2,594
For kernels, they seem to be very device dependent; different users and different devices have different results. I recommend trying one for a few days before judging it, because it may take a day to settle and for your use and performance to be accurately observed.
Reactions: NotJustAPhone
greydarrah
3,047
222
Any of the popular ROMs are great, and I personally find only slight, un-noticable differences between them. It's fun to flash new ones when you're board, and because you go through the effort of flashing it, the new one usually feels better than the old. Just make nandroid backups and flash away. It only takes a few minutes to switch back and forth.
Kernels are a different story. Each phone can like one better than another. Some come with lower voltage settings, which can increase battery life, but can also cause lockups and reboots. You can adjust/raise these voltages, but I don't have the patience for it, so I try to avoid them. Keep in mind that your phone may love low voltages. For me, Franco kernels rule, regardless of the ROM. I don't even waste time anymore trying out the native kernel, I just flash Franco's nightly right after I re-install my apps. I'm not saying that you should jump right on Franco, but find what your phone likes best.
In summary, your ROM provides the UI experience (customizations, toggles, etc...), and the kernel provides your power and speed...but that's just my opinion.
Swavek
150
3
if you're going to experiment with a variety of roms than i highly recommend titanium backup. with TB, you can backup your apps and settings easily than restore them later once you've installed your new rom.
anyhow, for a starter rom i recommend Redemption Rom. it's VERY close to stock and it runs very stable and quick.
if you want something more advanced than i either recommend liquid ics or aokp.
all of these roms can be obtained at rootzwiki.com
Reactions: SeigaGen
Spaniard85
55
I'm gonna toss my hat in with the AOKP crowd. It has a huge amount of customizations and is still fast and stable. I'm running the Build 38 re-release with Linaro and the included kernel, and all is well and very snappy. I'm thinking about trying franco again, just to see how it combines with Linaro.
grantith
10
5
If you want to try something less stock and more innovative, I highly recommend the Paranoid Android rom. It's based on CM9, but it has a hybrid tablet/phone interface that uses some of the features in tablet apps (like 2-pane Gmail and 3D YouTube) and a notification center on tablets. It's highly customizable, and has totally changed the way I use my Nexus. You can check out some screenshots & install instructions here:
GSM Nexus: [ROM] PARANOIDANDROID [CM9HYBRID] [120531-1.1b: TOGGLES, NEW MENUBTN, FORCE, ++++FIX] - xda-developers
Verizon nexus: [ROM] PARANOIDANDROID [CM9HYBRID] [120521-0.9b: PER-APP-LAYOUT, AN ANDROIDS FIRST!!!] - xda-developers
Reactions: Spaniard85
