Given Codes
Hellow can i use this method to unlock APN settings on verizon Samsung Galaxy S3??
Actually i managed to edit the APN settings with that method!Kudos
Hello...im using a verizon note 2 and rooted...did the following steps and only got the reset to default option when pressing the menu key...is this because im not running a custom rom??
Just one question, does my bootloader have to be unlocked for this to work or can I just be rooted.. Thanks
I would double check to see if you made the correct edit to the file . Perhaps you didn't save the change
From my Galaxy Note 2 via Tapatalk
I am having the same issue of not seeing the option to add an APN after adding the script. At first I thought it was because I added the script at the bottom of build.prop (which put it where the Jelly Beans additions were since I'm using a Jelly Beans ROM). So then I removed it from that spot and wrote it in exactly where you do in the video. Even upon entering it there, saving and restarting, it still doesn't show the option to add APN when pressing menu.
I am currently in Turkey and have turned off my mobile data and roaming. I thought that may be another reason for it not working, but even upon opening up mobile data and global data roaming I still don't see it working.
Any advice would be appreciated!
The latest VZW update for Note II (4.1.2) allows for the adding/editing of APN's. When Jelly Bean came out originally it didn't work but VZW business told me it was a bug and would be fixed in the next build.
Got the 4.1.2 pushed out to me last night from Verizon and now my Samsung Note II is fixed so you don't need the hack anymore, nor do you need to root the phone to use overseas SIMs. The ADD (+ ADD NEW ACCESS POINT) menu item shows up automatically now.
Every time I add APN, when I change the mcc and mnc it deletes everything and doesnt load??????
I tried using the above method for Verizon Galaxy S3 but it is no working. Please let me know if somebody has done it successfully.
