ok so i bought a phone from a reputable company in guam. It is a Note 2 and it is CMDA. So thinking that it says VW all over the phone i would be able to bring it back to the states and use it.. Well not so much took it to a store and the technition in the store or the on the phone helper could do anything to make this little one work. Now i have spoken with the company in Guam and they said to have VW program well it never gets past the activation part and fails out .. so my thing is .. how do you program a number in to the phone not using 4g because that requires a sim card and IT&E does not use sim cards. So far my phone only knows that it is roaming due to it being our of guam. what can i do to fix this .. i have already factory reset it every which way i can find on the internet and well this just sucks because i want to use the phone and have no way to do so.. Any help would be awesome.. I am actually trying to find the * numbers you can punch in and get to hidden menus so i think i might be able to fix it .. please help me !!!!
Patrick
Patrick
