I recently changed a setting on my Galaxy 3 that (as I understood it) would switch from wifi to 3g/4g if the wifi signal became too weak or unstable.
I was prompted to change the setting while using an iffy wifi network. Thinking it sounded beneficial, I changed the setting but now I can't find any way to undo it.
This new setting, I suppose operates as advertised but the unintended effect is that if I am using an app or game that requires a constant connection, the switch will crash the app.
Thanks for the help!
