10-19-2013 12:37 PM
57 123
tools
  1. RaSpewTin's Avatar
    Here are some suggested apps for people to check out which might help you not miss that LED so much. If you find an app thats missing please post the info in this thread so the first post can be updated. Thanks.
    NoLED (Free) - Androlib link - App brain link
    FlashNotify (Free) - Androlib link - App brain link
    Missed Reminder (Free) - Androlib link - App brain link
    Missed Message Flasher (Free) - Androlib Link - App brain link
    11-16-2010 05:24 PM
  2. smccloud's Avatar
    Better than nothing
    11-16-2010 05:53 PM
  3. kalex's Avatar
    Which one is recommended?
    11-25-2010 02:59 PM
  4. Gr8hifi's Avatar
    They're all different. Give all three of them a shot.
    11-25-2010 11:57 PM
  5. blackwaterstout's Avatar
    I just tried NoLED and I thought it sucked. I use Handcent SMS and when I received a text the quick reply box popped up and stayed there without ever turning the screen back off. I could see the NoLED icon floating around the screen behind the quick reply box but it seemed to cause my phone not to sleep Not cool at all.
    11-28-2010 07:31 AM
  6. jtay's Avatar
    I tried NoLED, but that was just an icon floating around the screen. FlashNotify flashes the whole screen, and also allows an audible notification every time it flashes. It doesn't work for emails and voice mails, only SMS and missed calls. That's fine though, all I was looking for.
    11-29-2010 01:19 PM
  7. KSmithInNY's Avatar
    Maybe email the developer and let him know theres a whole net set of phones on the market that need his app. Maybe he can include notifications for things like VM and email and stuff.
    11-29-2010 02:26 PM
  8. jtay's Avatar
    I already did.
    Voicemail, for me anyway, is usually the result of a missed call, so they kinda go hand in hand. Would be nice to have an email notification though.
    11-29-2010 06:38 PM
  9. 1D10T's Avatar
    I installed flash notify on my wife's phone and it works well. You have a lot of control over how often ur screen flashes and the duration. But does anyone know if it makes entering new contacts difficult?
    12-01-2010 01:08 AM
  10. mfldmike's Avatar
    Not really worried about notifications myself...
    I mean I check the phone frequently enough throughout the day that it doesn't matter if there is an LED notify.
    I always found those LED's to be annoying anyway, especially when you have a lot of emails or text a lot.
    I think the NOLED is a great concept and maybe if it was a static "better looking" image I would give it a try. I really like the idea of the screen essentially being off but a slightly transparent ghostly clock that showed through.
    12-01-2010 09:25 AM
  11. mjones1052's Avatar
    Sent from my DROID2
    12-01-2010 09:27 AM
  12. mfldmike's Avatar
    Sent from my DROID2
    ? What was sent from your DROID2
    12-01-2010 09:30 AM
  13. Bone_Enterprise's Avatar
    Clearly that message was.
    12-01-2010 09:31 AM
  14. mfldmike's Avatar
    Thank you captain obvious
    12-01-2010 09:51 AM
  15. blackwaterstout's Avatar
    Sent from my Optimus S
    12-01-2010 10:18 AM
  16. Nick7's Avatar
    The Samsung Moment had the same issue. A dude over at SDX developers made an application that lit up the capacitive keys when there was a notification. This might be possible for the Optimus S, however I don't know how effective it would be since the hardware buttons do not light up very bright.
    12-07-2010 02:11 AM
  17. blackwaterstout's Avatar
    Normally I'd say that was a much better idea than actually lighting up the screen. But as you mentioned the hardware buttons on the optimus are extremely weak and dim. Half the time I barely notice them in total darkness
    12-07-2010 06:17 AM
  18. kalex's Avatar
    Thats actually a pretty good idea. I rather these blink then whole screen
    12-07-2010 11:02 AM
  19. infid3lkastro's Avatar
    X2 on blinking buttons
    it's true they're dim, maybe that could also be addressed? also if they blinked independently
    12-07-2010 11:13 AM
  20. fatal99's Avatar
    First post, longtime troller. Using Flashnotify, will probably donate, it seems to be working quite well. I wouldn't even notice the buttons lighting up in my office, too much light going on, but a good idea for nighttime, I loved the little button on my Pre lighting up to let me know I had something waiting.
    12-07-2010 05:05 PM
  21. oraphus's Avatar
    I'v been using "missed reminders" app. its ok.
    the thing that really annoys me about it is that the little notification icon does not go away after you view the missed text. So that means you have to see the text and then again hit the notification icon for it to clear and stop flashing your screen.
    Also, Flashnotify does not stop flashing once it starts. Meaning once i get a text it starts flashing... then i view the text and leave the phone alone. But it continues flashing like i have a new text.. when i dont, and the one i had is alrady cleared from it. Anyone else notice this?
    12-08-2010 06:07 PM
  22. infid3lkastro's Avatar
    i use Flashnotify. i've noticed what you've just described and it annoyed me at first, but i've developed a new habit of checking things out thru the notification window/clicking the flash bulb. i find that saves me the trouble of chk'ing missed txt from the sms app and going bk up to clear notifications.
    12-09-2010 01:18 AM
  23. fatal99's Avatar
    If you go into FlashNotify settings in the AppDrawer (I think that's what it's called) you can set the notification frequency and how long to do it for. You can also choose to disable the bulb on the notifications bar too.
    12-09-2010 06:04 PM
  24. gogetter20002's Avatar
    I am trying all 3 since I cannot have my phone on me since being a mechanic makes it bad having your phone on ya while working, anything to get my attention is needed............
    12-12-2010 05:47 PM
  25. beav395's Avatar
    I started using NoLed and it seems to work fine. When a notification arrives a little icon appears on the screen. One nice feature is each type of notification has its one icon that appears on the screen. Email, SMS, voicemail, missed call, gtalk, etc. all have their own icon and if you have more than one type of notification multiple icons will appear on the screen.
    I was really missing a led light but this app completely solved the problem.
    Thanks
    12-13-2010 07:57 PM
57 123
Tags for this Thread
