Timmy E82 - camera doesn't work
A
AC Question
My camera and videos on my Timmy E82 won't woek - it just says that gallery is not working - how do I fix it?
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,602
4,751
113
Welcome to Android Central! I'm not familiar with that brand. Are you using the preinstalled Camera and Gallery apps, or did you install 3rd party ones? If 3rd party, there might be compatibility issues.
If you're using the preinstalled apps, then try going to Settings>Apps>All, and select Camera and Gallery, and Clear Cache and Clear Data from both of them. Force Stop both of them as well. Then try the Camera again.
danishpeer
