Note Edge Wallet Case with Qi
A
AC Question
I have a note edge and I got a note edge wallet case. When you close the case, it locks the phone. But when I put a wireless receiver in it, the wireless charging works, but the case no longer locks the phone.
After further inspecting I noticed the the case uses a pin that the wireless receiver also uses, I was wondering if there was anyway to get the to BOTH work.
itguyjax8430
Retired Moderator
Mar 15, 2013
6,822
Welcome to Android Central!
You might have to try to find a case that has the wireless receiver built in to it.
tivativa
