1. AC Question's Avatar
    Hey,
    I got the HTC desire 826 a couple of weeks back and updated it to the latest version of android. After the software update, it stopped connecting to my home Wifi. It'd either say "Disabled" or "Connection Error". I did a factory reset and it started to work fine (for about a week). Last night after the battery died, I plugged it in for the night as usual and upon turning it on this morning, the same problem appeared. It won't connect and I've done all the basic things I've tried rebooting it, turning on aeroplane mode, resetting my wifi settings etc. I love the phone but I can't keep resetting it every week.
    Is it some software issue with this model specifically? Why does this problem keep recurring? How should I fix it? I really need Help Please and Thank you
    03-01-2017 03:05 AM
  2. lsmachado's Avatar
    Hey,
    Welcome to Android Central! Here is a link to a guide for troubleshooting wifi problems:
    [GUIDE] Troubleshooting Wi-Fi Connection Problems
    Please consider registering as a new member here - it's free, so you can ask any additional questions or reply with any other information you can provide. Let us know if this helps you.
    03-01-2017 07:18 AM
  1. Why does my music only play with headphones
    Last Post: 03-02-2017, 12:27 PM
  2. Why won't my Google play update my apps
    Last Post: 03-02-2017, 12:25 PM
  3. How do I transfer data to my SD card on Galaxy S7 with nougat
    By AC Question in forum Samsung Galaxy S7
    Last Post: 03-01-2017, 06:17 AM
  4. Why can't I sync enable my Yahoo email account to my Android?
    Last Post: 03-01-2017, 04:21 AM
  5. Why won't my sim card go in
    Last Post: 03-01-2017, 03:08 AM
