Need Help Root Razr Maxx
CaliberSRT4
53
Im new to rooting. I cant root my razr maxx. Every time i get "adb server out of date". Im using droid razr utility 1.8. Ive updated my motorola drivers. I am on the .215 leak.
Sent from my DROID RAZR using Android Central Forums
strabo231
497
96
From what I have seen people have had better success with this. I can explain another way if this doesn't work, but this is much easier
CaliberSRT4
53
Anyone know how i can update my! "Adb server" so i dont get that message again? Thanks
strabo231
497
96
Using droid razr utility?
No sorry my link didn't attach
[TOOL][ROOT/UnROOT][Razr] EternityProject EasyRootICS [Win/Linux] - xda-developers
Usually if it says adb is out of date it means that the previous instance you were running didn't close. Just type this in the command prompt adb kill-server
so as an example if you let it install to the default location it would be
C:\Program Files\Android\android-sdk\platform-tools>adb shell then next line simply adb kill-server
To check for an adb update go to android file>android-sdk and open sdk manager. Top two I believe are adb. if the right column says installed you're good. If it says update then it will allow you to install updates from there
RandyRoyalty
