Rooted SPH-D710_Zedomax_EpicTouchKernel-v3 with oden. Everything went okay. Downloaded midnight ROM and put it on my SD.
For some reason when i go to back up my current ROM it's not working. It just brings me to a screen with a android and exclamation point in a triangle and nothing is happening.
Also when i go to install the ROM. CWM wont recognize any files on my SD card whatsoever. When i'm in ROM manager and try to install the ROM from my SD card it will find the file and attempt to install it. But it just goes to the same screen that comes up when i try to back up.
Any ideas guys? =*(
Been fighting this loosing battle all night long. I'm starting to think maybe the SD card is bad? But then why wouldn't it back up and why can ROM manager see the ROM on my SD card and CWM can't?
Any ideas guys? Any help would be much appreciated.
Any ideas guys? =*(
