Help! Need to retrieve text messages
Lindasueaa
I got my phone wet and it is very important that I see my text messages. Cant get to the phone store until later today. Is there a way you can retrieve text msgs. on-line? Any help would be so appreciated! Thanks
takeshi
969
30
This won't help you at all but you could definitely do so if you had been using Google Voice. You could even continue to send and receive messages without your phone (from a PC with internet access).
the phone is turned off?
or is the screen preventing you from reading the sms?
If it's wet it needs to be left off until it is fully dried which can take a few days.
Powering it up before it's fully dry is a great way to cause problems. Hopefully the OP pulled the battery ASAP.
broli
21
if the phone is tuerned off, i seriusly doubt you are gona get info from it...
unless you where saving you messages OUTSIDE the phone, you are out of luck.
but ofcourse, if you where saving the messages outside the phone, you would know this by now
samahmed336699
