i had a custom rom gingerbread and then i wanted to do a factory reset to go back to the stock room , instead this give me big problems. it is stuck on the lg screen and i try to go into recovery and alit says is do not pull out battery Formatting data , Formatting cache and Factory reset and this it goes right back into the lg screen where it gets stuck . My computer recongizes my phone but i dont know how to use adb commands thing like a pro . i have everything i need in the folder "backup" in the clockwordmod folder . COULD ANYONE HELP ME FIX MY LG OPTIMUS V
