Hi all. So, a couple of days ago I dropped my Acer Liquid Express on the pavement, and the impact caused it to shut off, and stay off.
If I plug it into a charger (wall or PC) the screen lights up and it shows itself to be charging as usual, so there's still some sort of life in it, but it won't register a charge in the battery (it was on at least 50% when I dropped it). It also won't respond to any button presses, meaning I can't turn it on, perform a hard reset or access it from PC. I've tried the usual tricks, taking out the battery and sim card, holding the power button for x amount of time, and I'm currently leaving it on to charge for a couple of days to see if it wakes up.
My question is, is my phone salvageable or would I be better off throwing in the towel and replacing it? Is it possible a replacement battery would kick it back into life? It isn't completely dead, as it displays the charging animation when I plug it in, but I'm really not sure what can be done with it at the moment.
