I have a Galaxy Note 2 and can't figure out how to record via my bluetooth headset not via the phone mic. Tried 20+ apps that record great via the phone mic but not via my headset.
Any ideas?
Thanks.
Any ideas?
Thanks.
You can record audio with a simple app called "Bluetooth Audio Recording".
Good luck. From what I've seen, intercepting BT mic audio is locked down about as tight as the N900A. Stupid idea for an "open source" phone, but the boogie man may be listening in on your phone call.Mono Bluetooth Router doesn't work. Can't work. I've searched the Play store and I haven't found an app yet that will do the job. Gonna have to write one.
Well I wrote one that works fine on my old Droid Bionic. But I was only interested in solving my problem - not releasing it for general consumption.Good luck. From what I've seen, intercepting BT mic audio is locked down about as tight as the N900A. Stupid idea for an "open source" phone, but the boogie man may be listening in on your phone call.
there is one on the google play store that worked for my SGH-I537 running 4.4.2. since i cant post links yet but its called "Bluetooth Voice Recorder" on the play store worked for me and just came out on the play store on the 1st of march
