help my phone boots up then shuts off LG optimus 2x
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,602
4,751
113
Welcome to Android Central! Have you tried pulling the battery and waiting about 10 seconds before putting it back in and restarting? While you have the battery out, lay it flat on a table and spin it. If it spins freely, the battery is probably going bad (it's bulging in the middle), and you might want to see if a new battery fixes the problem.
Otherwise, you might have to do a full reset following these instructions: How to hard reset the LG Optimus 2X | The Full Signal
tress
