I have an unlocked Samsung Galaxy S3 and I've been trying to get it to work on AT&T's networks using the gophone sim card but it doesn't want to stay connected. I can send text messages most of the time, but it will not allow me to make/recieve phone calls, or use data. I'm pretty sure that I have the right APN settings and I haven't changed any other settings. I called Samsung customer support (really good support) and they said that I might have to see if AT&T will re-flash my phone so it will work on their network.
Has anyone else had this problem with their unlocked S3? If so, how did you fix it? Any help is definitely appreciated!
