Mooncatt Ambassador Feb 23, 2011 10,759 321 83 Visit site Mar 10, 2014 #1 When pulling down the notification bar and you see each notification's title and subject lines, many times the info in the text is wider than the screen. Is there a way to get the text to scroll so you can see the entire string?
Golfdriver97 Trusted Member Team Leader Moderator Dec 4, 2012 35,367 113 63 Visit site Mar 12, 2014 #2 You can pinch to expand some notifications. See if that works.
Mooncatt Ambassador Feb 23, 2011 10,759 321 83 Visit site Mar 12, 2014 #3 Tried it, but it only works if the app makes the notice in multiple lines. Usually they don't.
