Kernels
Blazalin
15
I want to flash a new kernel and was wondering what matters when I flash it? Do i need the kernel to be 4.4.2, galaxy s3, and d2tmo based? Or just have it linked being 4.4?
Aquila
Retired Moderator
Feb 24, 2012
15,904
They way I understand it, you can use a kernel that's from the same API level as your ROM and it'll work, it just won't be optimized if it's not for the specific build or base build that your ROM is on. For example, you can use a 4.4 kernel on a device running 4.4.2, but a 4.4 kernel won't work properly (or at all in some cases) on a 4.2.2 ROM, and vice versa, etc.
Edit: For clarification, 4.4 and 4.4.2 are both API level 19.
Blazalin
15
What about the phone model? What if the kernel is given for nexus 4. can i use it for galaxy s3?
danishpeer
