I have an LG Optimus G Pro. Suddenly it started saying letters out loud as I type them, even when my phone is on silent. How do I make it stop? Its not the talk back feature as that is turned off and its only the keystrokes that are being said.
Welcome to Android Central! Have checked all of the other Accessibility options in Settings>Accessibility? Or the keyboard options in Settings>Language & input, then pressing the settings icon next to the keyboard you use?
I have tried all of that. This is driving me crazy. I think its the LG keyboard option that doing it, which I have always used since I got the phone last summer. I don't really care for the android keyboard.
Here's a thread from another forum that discusses the same problem with another LG phone. It was mentioned that some apps like Lightflow can interfere and cause TalkBack to work, even if it's turned off. They suggest uninstalling or disabling TalkBack.
