Power Button and Ending Calls
FinalStar
After a search of the net, I haven't found a solution to my issue. I have a LG G2, Sprint, Stock 4.4 + Root. The power button on my phones ends calls, and I cant tell why. The settings in Accessibility and Calls are both disabled. I have cycled the setting in both locations several times, made calls, and reset the phone with no luck. I was hoping the community could help me figure out what to try next besides factory reset or installing a custom ROM.
I have the same problem on a verizon G2 4.4.2 stock unrooted. LG says it's VZW fault on the OTA side. I have found no solution.
lefler
