question on "search"
hello,
while i am loving google launcher, the ok google stuff, i noticed that google search is not able to search apps in the phone as good as ios dose. For example, in ios, i simple type "bay" and any app that contains "bay" will pop up (i was try to search ebay app). On the other hand, in google search, i type "bay" only the apps begin with "bay" will pop up (ebay wouldn't pop up uless i type "eb").
Any suggestion that i can make app search as good as ios?
i use note 3
thanks!
hello,
i use note 3
thanks!
