Who doesn't my S-voice or task manager or the slide on top of the phone work?
A
AC Question
who doesnt my s-voice or task manager or the slide on top of the phone work?
2 weeks ago some kids in my home played with the kids mode and forgot the password then i had to force remove it and i removed it by trying several ways, but then after a while the s-voice doent open and the task manager doenst open and also the notification bar doesnt slide , so whats the solution to that by the way the home button works perfectly fine....Need help :)
