Problems after trying to update phone to Lolipop
I use Micromax Unite 2 A106. Today the phone received the official Lolipop update(around 413MB). The phone was nearly at 60% battery when the download started. After a few hours, when i tried to check the update progress it restarted. At that time, the phone was nearly at 100%(i had been charging the phone during the download process).Then after an hour or so, i saw that th notification light on the phone was blinking red. I quickly plugged in the charger, thinking that the phone was about to turn off. After plugging in, i tried to unlock the phone, but the screen refused to turn on. then i was compelled to take off the battery and turn on the phone.
After turning on,i saw that i was still at KitKat and then when i tried to restart the update process again, it would'nt start.It gave the error message-
"The update process is not responding"
Then it told me to either wait for it to respond or cancel the process.After cancelling the process, i tried to load a few apps like Facebook, PlayBuzz, and Video Player. But none started. When i went to the file manager, i saw that it was completely empty-no external SD card or internal memory options were present, nothing completely blank.
What should i do?Please help if you can.
