A
AC Question
Apps Can't write anything and doesn't have permission to write on Internal SD Card
Hi guys I need help with my old phone Samsung Galaxy Trend Lite with it's Internal SD Card. I think it's broken. Here's the story: It's friday night I turned off my phone and boot it up again then the problem occured. I went to my filemanager and its says 0 files on sdcard0 -internal. Then I went on to settings>storage and its says that system memory is normaly about 2GB but its says 4GB and qll my internal sd card have is 4GB. Thats wierd. I tried factory reset but still the same. I need fix for it ASAP. Thanks
