Dreadful battery life on Wiko Rainbow
Hi everybody,
I just bought this smartphone some time ago. Ive been pretty satisfied with its overall perfomance, the screen quality, the stock android it runs. Coming from a 512mb RAM device i couldnt be more satisfied regarding this smartphone pros.
However, I simply cant stand this smartphones battery life. Its absolutely awful, dropping to 50% in 2 hours with moderate use(Chatting on FB messenger, browsing the internet, listening to music). Even if i use the smartphone lightly(only chatting), the battery still drops awfully fast. I dont consider it normal at all, because my other smartphone with 1400 mAh battey lasted MUCH better, dropping only to 70/75% battery if i used it the same way I use this phone.
Seems like no matter how lightly I use this smartphone, the battery keeps dropping like i never seen. Any help there? Ive bought this phone 5 days ago, could the battery still be "asleep"? Any suggestions?
Thank you in the advance. Here are some screenshots demonstrating the problem:
P.S - It's on Portuguese but it's fairly understandable.
Hi everybody,
