I have a couple of issues and I am coming from a BB Storm and I would think that these are available on Droid2.
First, I am use to automatically connecting just by starting the car. With the Droid it seems I have to open setting, select settings, open wireless & networks turn on Bluetooth, then Bluetooth settings, then make it discoverable. I have to be missing the picture here...I cannot believe that I have to go through this routine each time I get in my car.
Second, is there a setting to enable an LED to indicate that you are connected to a Bluetooth device? I can't find it anywhere.
Thanks for all you do.
