LG Spirit 4G LTE usb cable just charging, can't switch to data transfer
scigabacsi
Hello everyone!
I've got an LG Spirit 4G LTE phone and even i plug the cable to the computer it's just charging and data transfer is not possible.
When i tap the notification screen there wasn't a charge phone button, like in this picture:
http://support.bell.ca/Mobility/Smartphones_and_mobile_internet/LG-G3.how_to_change_the_usb_connection_options_on_my
Is it possible to somehow change the charging into data transfer?
Thanks for your help.
Mooncatt
Ambassador
Feb 23, 2011
10,758
321
83
I would try another usb cable
Ditto. Not all USB cables are created the same. Most charge and sync, but some cheap ones only charge, some only sync. If this is the OEM cable or one that used to sync, then the cable most likely went bad, which is common.
Non
