Had the phone format sd card as adoptive storage, works for a while then but as some apps install to internal storage which in turn gets full and then adoptive storage
no longer works,
no option to move apps over to sd card
cannot download or install anything as phone is always seen as full
Is there anything that can be done to get it working again apart from resetting phone
Thanks
no longer works,
Thanks
