Don't know if any one has done this but I thought I would share my little project to the ac fourms.
So I'm taking my old gnex car dock and I'm going to remove some of the plastic shell that holds the classy gnex. I will then take a N5 case and cut out some key areas, and ideally just use some epoxy to hold the two together.
I will add some photos and update along the way but if any one has some tips to help the process then fell free to add your 2 cents.
UPDATE #1
That's my case that I cut already
The gnex car dock that I have(using the non pogo pin version)
So I took apart the car dock, and just held the two cases together and traced the finger pusher out so I can easily get my phone out after. Also because I still want to be able to take apart the dock and add a NFC sticker in the back I cut out the samsung door, unfortunately I doubt my case will hold to the car dock case when I try to bond the two together due there not being enough structure in the middle. I will still try but I plan to get another N5 case and not cut out the Samsung door part.
UPDATE #2
OK so I got a new case and I only cut out the finger bang to push my phone out easily.
Also cut out most the plastic of the gnex car dock and only left the Samsung door, because the gnex had a curve to it I needed to have a straight part of the dock which would have no gap.
I used epoxy to hold the n5 case and what's left of the gnex dock. Let it sit for a bit and it looks to be holding fine. I haven't tried to pop off the gnes Samsung door from the n5 case yet, but it should open up and allow me to put a NFC sticker inside.
UPDATE #1
UPDATE #2
