Hi. My nexus 7 will not charge. When plugged in it does not charge. The charging port wiggles around and seems loose. Has anyone lese encountered similar problems and found a fix?
My best friend had this issue a few months back. We tried everything we could think of but ended up having to just RMA it. You might have to go that route as well. Faulty charging port. Good luck!
Unfortunately it's very common. Do the RMA or if you don't want to ship it off, buy the dock. I bought the dock when mine stopped charging and it works great!
