I am looking for a horizontal belt pouch that will fit my incredible w/ seidio innocase surface. I tried the verizon model but it was way too tight even with the case off the phone, and impossible to use with the innocase on the phone.
Measuring the phone with case and then allowing for some ability to actually get the thing in and out of the pouch without a bunch of drama it looks like I need something with internal dimensions of about 5" x 2.75" or slightly less.
I would like a pouch that leaves the earphone port open so I can plug in a cable and use it while the phone is in the pouch. (the particular device doesn't work with bluetooth). However, if I could just get a pouch that fit the phone I can cut a hole in the end for the cable.
Is there a phone that is slightly longer and wider than the Incredible that I should look for a pouch? Does anybody make horizontal belt pouches for the incredible with a case?
Thanks
Thanks
