Re: [How-To] Rooting LS670ZVH
I think it is complaining about rage/rageagainstthecage. This is a root exploit executable that runs on your phone, not your PC. In some sense some might consider it mal-ware since it roots your phone, but that is exactly what you want to happen in this case.
I'm not using security essentials but when I scan the zip nothing is flagged.
You can try scanning the zip file in the ZVC root thread and see if you get the same warning. These are the same root exploit executables.
http://forums.androidcentral.com/lg...-guide-rooting-software-version-ls670zvc.html
Can you click on "Details"?here you go i took a screenshot to show you what i get when i scan the .zip
