[How-To] Manual Rooting of LS670ZVH/ZVJ (+ links to root ZVD/ZV9)
Amber.scheel
10
Re: [How-To] Rooting LS670ZVH
I need help! My phone was rooted under ZVD with Gingersnap, yesterday my phone got updated to the ZVH and it unrooted my phone. How do I reroot with the ZVH already running now??? Please help me.
donbudafuko
304
4
Pob not the place to ask but was just wandering if I can put a customerecovery on with out having roo I have stck gb just was wandering
pilot03
97
6
Little trouble with rooting ZVH. I got it updated and started the root method posted. Everything goes smoothly up to doing the push for rage, su, busy box, but when I have to enter adb shell it is not found. Am I missing something?
memsman
142
19
I don't recall the exact step, but you can check whether usb debugging is enabled.
Nete
11
My phone I think has already downloaded the update but it hasn't been installed. There isn't any update.zip on my sdcard already so I'm assuming the update was put internally on the phone. If I download the update.zip and put it on my sdcard will there be conflict?
Thanks
blackops1125
Advisor
Mar 19, 2011
1,037
184
Are the files in the right directory, so that adb shell can fine them?
sent from my CM7/Reborn w/ 1 Gb internal storage Optimus S
Always happy to help, hit that thanks button if I did
pilot03
97
6
Please explain. I have sdk added and everything downloaded from the root setup. Other then that, I don't know why it won't get past the adb shell process. That's where I get stuck from finishing the root. Your info is much appreciated.
sfhub
2,384
741
Just get rid of or move the OTA update.zip so it doesn't take up space. It is in your /cache directory (internal storage on the phone)
sfhub
2,384
741
Could you confirm you took care of Part 6 - Note #1 (run the V8->V9 update.zip to mount /system)? There is link to a picture of what you should have seen on your screen in the first post.
sfhub
2,384
741
Is there a way to roll back to ZVD??
Yes, you can roll back to ZVD. You do not need root. Just follow the instructions in the 2nd link of my signature. Substitute the ZVD cab (found in the reference section) for the ZV9 cab in the main instructions of that post.
dpollard55
12
3
If your on Windows 7 64bit then copy su rageagainstthecage-arm5.bin and busy box to C:\Program Files (x86)\Android\android-sdk\platform-tools then when you open the command prompt in windows change to this directory cd\Program Files (x86)\Android\android-sdk\platform-tools now adb shell should work and find the files.
Alternative method to run adb shell any where within Windows..... right click my computer and choose properties... click advanced system settings... choose the advanced tab at the top then choose environment variables at the bottom... in the bottom window scroll down to Path and choose Edit... in the variable value field paste this at the END of everything else DO NOT DELETE ANYTHING IN THIS LINE... ;C:\Program Files (x86)\Android\android-sdk\platform-tools .... click ok on all the windows and now you can run adb shell from any folder
hohenheimofdarkness
