[ROM] JB 4.1.2 SlimRom for LS670 3.1 Build3
thekraven
1,407
1,148
SlimBean 3.1
Freshly unofficially built SlimRom Jellybean 4.1.2 for the LS670. Radio works on JB 4.1.2. ZVD based
Features
  • Notification Sound Toggle in PowerWidget
  • Custom backgrounds & transparencies added to Notification drawer background & rows
  • Lockscreen background transparency moved to background customization
  • Lockscreen transparency works on the fly now
  • Lockscreen background 0-100% alpha can be activated on colorfill and custom background
  • Lockscreen clock moved in settings to widget behaviour.
  • Lockscreen clock style could be customized now + hidden feature
  • Optimus and BB lockscreen can now be colored and you can change transparency as you like
  • Optimus background settings deleted cause of new stock background customization ability
  • Ability to choose a custom lockscreen before secure lockscreens
  • Vibration support for optimus and BB lockscreen
  • Whole lockscreen settings are working dynamically now and show just what is possible to customize
  • Notification drawer - transparency of notification row can be set
  • Notification drawer - add support for custom landscape background
  • Notification drawer - add support for background color fill
  • Notification drawer - reset of background image not any longer over menu
  • Notification drawer - moved whole style options in style category @settings
  • Volume key cursor now affects all keyboards
Fixes
  • System - Turn off screen fails sometimes
  • System - Transparency standard value of statusbar to 0%
  • MMS - Settings option black theme function back
  • Lockscreen - Several music transport control fixes
  • Lockscreen - BB tablet support
  • Lockscreen - Peformance improvements for optimus lockscreen on hdpi devices
  • Lockscreen - Owner info shows on lockscreen
  • Notification drawer - Dotted circle battery in notification drawer
  • Notification drawer - Custom background image landscape (scales now)
  • Notification drawer - Stock background at 0% transparency is now properly opaque
More info: SlimBean 3.1
: Slim Bean Features
BUILD 1: initial build. Wifi, radio works
BUILD 2: Youtube HQ works, Camera works, Gallery previews working
BUILD 3: Added cron a2sd+ script, fixed sd-ext mounting, added partition info to settings, added apollo, email, exchange apps, updated hololauncher and superuser,
added in build.prop tweaks, offline charging, DSP still fc, but music will play.
BUILD4: Camera broken, DSP fc fixed,voice dialer added,Seeder init.d script added, wifi tethering patches, didn't work,
Download
Install:
  • Requires a full wipe in the recovery
  • Flash the rom zip
  • Flash the slimRom Gapps
  • Reboot.
  • NOTE1: no sd-ext scripts included. Now included in build 3
  • NOTE2: test kernel 23 included, but you can flash other CAI kernels
  • NOTE3: Animations are turned off, so turn them on to 1x to see them and reboot.
  • NOTE4: Virgin uses will just need keypad changes and build.prop changes: See attachment below. You can change the carrier label in settings
  • NOTE5: If vibration isn't working, try CAI test kernels 21 or 38.
WHat works... Radio, wifi, market, Camera, Camcorder, Panoramic, Youtube HQ
BUGS ... Music app not reading music files, download Apollo patch post #38. OTA fc's till i remove it. Fastcharge toggle icon is too big
Thanks to SlimRom, BobZhome, LeslieAnn, drew, tdm, and Popdog123 for the sources to build.
https://bitbucket.org/thekraven/iscream_thunderc-2.6.35-rebase
https://github.com/slimrom-thunderc
https://github.com/SlimRom-for-p500
  • Virgin.fix2.SLimRom.zip
HaiTek
10
Re: [ROM] JB 4.1.2 SlimRom for LS670 3.1
Looks awesome! Are there any significant differences between this and JBC (other than the radio working of course)?
thekraven
1,407
1,148
It's downgraded Jellybean, so similar to cm10 and more stuff should function. SlimRom is Jellybean 4.1.2 and JBC is 4.2.1
jasonevil
307
110
flashing now, on a side note, the link to the gapps didn't work...said unauthorized download...
pellik333
79
7
Using it right now and it seems to be sooooo completely beautiful. Very stable actually. My new daily driver. Great work dude. This is awesome. So smooth.
Sent from my Slim LG-LS670 using Tapatalk 2
thewraith420
1,987
223
63
And kraven the great pulls yet another rabbit out of his hat!! Nice job, and here I thought I was going to settle down with cm7 and just sit tight. Guess I'll have more to play with when I have time.
Tapatalk'n it from my VM670 running OM-Mandylion IHO on LS670ZVJ firmware
duffieldj1
137
18
Wow Kraven is all over development, Thanks Kraven! I'll be flashing and testing all of this soon
hlxanthus
1,790
411
thekraven, my hats off to you!! I have LOVED slimRoms when I have run it in the past. OptiS users, what a treat for you all. Nice work.
Axe
200
3
So, what is removed/different from this compared to the BobZhome version in the other thread?
_alexkta
289
This is like 30 Mb's less so more space for you
Sent from my LG-VM670 using Xparent Cyan Tapatalk 2
thekraven
1,407
1,148
I haven't looked too much into what's removed. Mostly language support, ring tones, voice dialer,and tts.
thewraith420
1,987
223
63
Any plans to have a flash able keypad and build prop patch for VM users?
Sent from my LG-LS670 using Tapatalk 2
AmeliaRodriguez
