I got tired of waiting for the OTA to push so I found a good a copy that seems to be the official ICS package. I flashed two nights ago using RSDLite 5.7 and everything is working just fine.
Here is the step by step of what I did Last night.
Android 4.0.4 System Version 6.16.217
6.7.2-180_DR4-16_M2-37
Blur_Version.6.16.217.XT894.Verizon.en.US
1. Download the software package (803.5 MB)
2. Download and install RSDLite 5.7
3. Download and install the Motorola USB Drivers
4. Power off your phone
5. Connect your phone to your PC with USB cable.
6. Hold the volume up, volume down, and power buttons at the same time until you see the bootloader menu
7. Use the volume down button to navigate to "AP Fastboot" then use the volume up button to select it
8. Open RSDLite, press the "..." button at the top, and select the image .zip file
9. Select "Decompress And Start Flashing" and wait for the process to finish (it will take around 30-40 minutes)
10. During this time the phone will reboot and you should see the Android upgrading screen followed by another reboot and loading into initial phone setup once ICS starts.
MAKE SURE YOUR PHONE IS FULLY CHARGED BEFORE YOU DO THIS!
To my knowledge there is no way to return to gingerbread once you do this update.
Take note that I did this upgrade after flashing back to a stock gingerbread package, I do not know if it works with rooted/modded setups. if anyone tries this out on rooted or modded please let us know.
