Hello,
I need some help. I just purchased the Motorola MH6X battery for my DroidX phone. A while back, I got the Seidio battery, but after GPS problems, stopped using it, and now I am in need of another battery, so why not get the 1800 rather than 1500, right?
Well, anyways, I got it, and charged it up (although it only took a short time for initial charge). I took it off,and within 30 minutes of very little use, it was down to 70%. Within 2 hours, the battery was completely drained, so I would charge it and same thing happened. One time, I was in a jam, so I switched back to original battery and when that died, I put the new BH6X battery in, and when I connected it to charge, it was sitting at 80% charge (which means that somewhere, something is going on and it is causing the battery to say it is dead, when in reality it is not dead).
Well, after enough of this, I called up the wonderful people at the Store, and they sent me a new one, and I returned my old one.
WELL, it appears the same thing may be happening. I just got it yesterday. I plugged it in for 2 hours last night for full charge, then unplugged it before going to bed. Now I know my phone uses very little if any battery power overnight, since data connection is turned off. Got up around 7 this morning, and my battery was reading 20% by noon. It got to 5% at 2:30 today (without any use at all between noon and 2:30), so I plugged it in. Within 30 minutes, the battery already had a 50% charge.
Am I going down the same road with this battery? Did anyone else have this same problem? Do you know how to fix it?
Thanks
Thanks
