I'm wondering if anyone else has any suggestions for this kind of problem with my SD card.
I just noticed that I have a notification about my SD card. It says its blank and safe to remove. The message also says it has an unsupported filesystem. I haven't been messing with it at all, so I'm really not sure what caused this or what to do about it. I tried formating from the options on the phone, but it doesn't work properly. It asks if I am sure I want to format, I press Yes, and then nothing happens.
I've tried removing the card and reinsterting. Also, upon plugging it into my PC, it doesn't register as a removeable drive as it usually does.
Anyone have any suggestions?
